Dumb Furler Question... - SailNet Community
post #1 of 12 Old 6 Days Ago Thread Starter
Hello,
Im new to the sailing world, and last year my boat was only rigged up so that I could use the main sail (the guy couldn't find the furler when rigging) so I had no head sail.
I have since located the furler drum and realized that there is no swivel. Nothing was at the top of the forestay or in the box of parts...
The dumb question: Do all furlers require a top swivel to work indefinitely? If it matters, its a Schafer 600 furler.
Thanks
DaveyRye is offline
post #2 of 12 Old 6 Days Ago
travlin-easy's Avatar
Re: Dumb Furler Question...
It depends on the furler. Some, such as my Alado, has it's own halyard and no swivel at the top of the sheaves.
Some jib sails have a cable built in that the sail is raised on and the drum attaches to something other than the forestay, usually a deck pad eye.
Just need more information in order to provide the help you need. Make and model of the drum would be beneficial if you can find it.
Good luck,
Gary
travlin-easy is online now
post #3 of 12 Old 6 Days Ago
Never seen a furler without a swivel. Not sure how that could work. The swivel is needed to allow the sail to wrap around the forestay without wrapping the halyard around the forestay.
Loki9 is online now
post #4 of 12 Old 6 Days Ago
No such thing as a dumb question if you don't know the answer to something but googling up Schaefer would have taken you to this site.
https://www.schaefermarine.com/our-p.../furler-parts/
They don't list a 600 but that doesn't mean they dont have parts for what you have. And yes you must have an upper swivel assembly. Contact them and I'm sure they'll help.
donsboat is offline
post #5 of 12 Old 5 Days Ago
Originally Posted by DaveyRye View Post
Hello,
Thanks
What size of boat is this?
Does the jib have a wire sewn into the luff? Or is there a tape on the luff that looks like it should slide into a groove?
I don't know what a Schaeffer 600 is. They used to make a free flying furler for smaller boats Maybe still do, but I think it is a 650. Best to send them a picture of the drum and ask for documentation and availability of spare parts.
FreeAgent is online now
post #6 of 12 Old 5 Days Ago
Loki9, take a look at the Alado Furler video - no swivel at the top - different system setup and does not use the boat's halyard, which is why it is not needed. I've been using an Alado for nearly 10 years now and love it.
https://vimeo.com/4847741
When I first got my Morgan it had an old jib with a cable sewn in and the drum attached to an eye at the back end of the anchor chock while a swivel attached to the halyard that was then attached to the top end of the jib cable. Basically, it was a piece of crap that was always binding. I replaced it a week later with the Alado.
Gary
post #7 of 12 Old 5 Days Ago
The Alado is interesting, I had not seen one like that before. The downside is that you can't get a lot of luff tension on you jib, but for small boats I guess that is not a problem.
Loki9 is online now
post #8 of 12 Old 5 Days Ago
Actually, my luff is as tight as a banjo string. It all depends upon how you set up the internal halyard.
Gary
post #9 of 12 Old 5 Days Ago
Hello,
Thanks
Do you have a foil (a slotted extrusion over the length of the forestay)? There are some hank-on furling setups but they don't work well.
I'd expect the Schaeffer to have a foil and a drum at a minimum (if it uses a contained halyard like Alado) and if the halyard is on the mast, then it definitely needs a halyard swivel.
If you've only just found the drum, perhaps there are many more missing parts. btw pics would help a lot.
Faster is online now
post #10 of 12 Old 5 Days Ago
I now see that Davey is same guy that was asking about an outboard for Mirage 26.
Not having heard of a Schaeffer 600, I was thinking it might be the type with separate drum and swivel and wire sewn into the luff that would be installed behind the forestay. It could be, otherwise not sure how he could have mast up and only just have found the drum! Any foils would need the drum to support them and he did not mention foils.
Anyway, he needs to get back with more info and pics.
No Question too Dumb? Tree Electrical Systems 7 01-29-2011 09:10 AM
Really dumb question.... Mizu General Discussion (sailing related) 52 01-24-2011 05:26 AM
Help--Really dumb question Barquito Gear & Maintenance 4 08-08-2010 02:47 PM
This might seems like a dumb question but I'm new so... MARRSY Gear & Maintenance 8 09-24-2007 10:03 AM
Dumb question, but please help.... FrankLanger Gear & Maintenance 7 07-06-2007 12:12 AM
