Y-valve - SailNet Community
 1Likes
  • 1 Post By JimsCAL
post #1 of 7 Old 3 Days Ago Thread Starter
Y-valve
New to me boat, new systems, old questions. Dumb question are better asked than not.
I have to replace the Y-valve for my holding tank. The valve I bought can be used in a couple of ways. Now, in one orientation I should connect the head with the holding tank. The other should connect the holding tank with the macerator. That way, I turn the valve, turn on the pump and the holding tank is evacuated. Correct?
DonScribner is online now
post #2 of 7 Old 3 Days Ago
Sailor
Gladrags1's Avatar
Yes. That's the way I would hook it up.
Gladrags1 is online now
post #3 of 7 Old 3 Days Ago
JimsCAL's Avatar
Re: Y-valve
Hard to say without more information. My system has two Y-valves. One at the outlet of the toilet always discharge to the holding tank or directly overboard (when allowed). The other installed at the outlet of the tank allows selection of the deck waste connection for a pumpout or to a diaphragm pump for discherge overboard (when allowed).
You seem to be mixing the two functions and locations and it's not clear how to do that.
fallard likes this.
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
post #4 of 7 Old 3 Days Ago
fallard's Avatar
Re: Y-valve
My setup is like the one described by JimsCAL--2 Y-valves, and for the same reason.
fallard is online now
post #5 of 7 Old 3 Days Ago Thread Starter
Re: Y-valve
I have no Y-valve at the toilet. Just a clear hose bringing water in and a white waste hose that goes thru the bulkhead and connects to the y-valve. I'll check again but I am pretty certain that the other end of the hose goes directly to the macerator. It's actually quite alarming, the number of holes that a boat has in it's bottom.
post #6 of 7 Old 3 Days Ago
JimsCAL's Avatar
Re: Y-valve
It would not make sense to connect the toilet outlet to the macerator pump. If the toilet outlet is connected to a Y-valve, I would expect it to allow the output to go either directly overboard via a thru-hull or to the holding tank.
S/V First Tracks
1985 Cal 33-2
post #7 of 7 Old 2 Days Ago
chef2sail's Avatar
Re: Y-valve
Our Y valve....one ...is after the holding tank. Less joints...less clamps....less chance for issues
One direction goes to a mascerator then is to a thru hull for overboard discharge when permitted
Second direction is to the deck pump out
There is a lock on it the CG has checked when they board to sail nsure the overboard discharge is not being done.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
Why, oh Y- Valve" sailingtime Gear & Maintenance 7 03-13-2016 11:49 AM
shut valve vs anti syphon valve Bluto Diesel 17 12-29-2015 04:25 PM
Toilets, Y valve or not Y valve VIKINGBEAR Gear & Maintenance 43 12-24-2015 03:39 PM
Joker Valve? WanderingStar Gear & Maintenance 13 11-07-2010 07:15 AM
Replacing SeaCock Gate Valve with Marine Ball Valve saurav16 Gear & Maintenance 30 06-15-2007 10:52 PM
