02-06-2007
While Rod rigging is generally quite reliable, it does have one major disadvantage over wire rigging. It can fail catastrophically, with little or no warning. I highly recommend inspecting rod rigging very thoroughly at least twice a year. If you don't know how to do so, hire a rigger to do so and have them teach you how while they are doing it.
The real problem for a cruising boat is a that rod rigging is very difficult to replace in remote areas... wire rigging is fairly easy to replace, with the advent of swageless fittings, like Hayn Hi-Mod, StaLok, etc. You can usually carry a single piece of 1x19 that is as long as your longest piece of rigging and the fittings, and use it to replace anything that fails. That isn't possible with rod rigging.
