02-11-2007
Originally Posted by 1970Columbia34
I have no history with the VC17 so I wanted to ask here first, but sounds like its good stuff and we should stick with it. Does it need to be re-applied every year and how many qts or gallons do I need for a 34' boat.
That depends on local conditions and your usage. It's an ablative paint, so racers or distance cruisers will wear it off faster. Also, if you bother to swab down the sunny side at dock more than once a season, you can get the slime off and stretch it to two seasons...again, not if you're a racer, I guess.
My 33' foot fin keeler took exactly two and one-quarter quart cans (or what looks like a quart can!) so I usually give ten bucks to a guy with a boat that takes two and three quarter cans! Concentrate on the leading edges and the rudder...the bottom of the fin doesn't get so much light. Also consider if you have a dock which way the boat gets the most light. My new boat in bow north and starboard to the morning sun, port to the dock's shadow, and the fouling is significantly different, as in swipe clean on port and reapply on starboard and aft.
