02-09-2007
Seinor Member
An old Bicycle Rim
It works just as good as all the fancy expensive antennas. I just find an old bicycle rim. Then cut it on one side. Dive in a dumpster and get a piece of PVC pipe, plastic, whatever and attach it to the rim so it holds the rim together without the two sides of the cut touching. Get one of those cable adapters that you can attach by screws and the other end has a cable connector. Attach the adapter with one lead on each side of the slot. Attach a cable, hoist that sucker up the mast and open a beer.
It's that simple and will work better than anything you can buy under $200. Or I Will refund your money. It isn't real great on the UHF channels.
Coming to you live from Staniel Cay Yacht Club
PS, I do not have an INTERNET connect all the time, as I am cruising right now, I will get back to you if you have any questions.
Fair Winds
Cap'n Dave
