12-30-2001
prop shaft coupler
I would like to purchase a prop shaft coupler from PYI to be installed on my Seasprite 28 with Universal diesel model 5411, and Hurth transmission. If this coupler is bolted between the shaft and transmission, does this in any way affect galvanic current flow to the zinc screwed onto the end of the prop shaft. Is there enough of a conductive path through the bolts?
