Old 02-15-2007
adsadler is on a distinguished road
Painting a Zodiac sole
Has anyone had to repair the wood in the bottom of their Zodiac before? What kind of paint is best to use?
Old 02-15-2007
camaraderie's Avatar
moderate?
Use MARINE grade plywood and coat with epoxy. Alternatively, you might think of using something like starboard instead which is lots more expensive but need no work and never will.
Old 02-15-2007
Thanx for that info, but I still have the original wood and it's in pretty good shape. I just need to touch-up the paint on it and want to make sure I get the right kind. Any Ideas?
Old 02-15-2007
Why don't you sand it, and the fiberglass and epoxy over it. That will make it last a long, long time.
Old 02-15-2007
Valiente's Avatar
I chipped the strakes on my Zodiac RIB in a couple of hard beachings, sanded it, put in mayo-style microballoon fill, sanded that, and then glassed on three layers of increasingly wide fibreglass tape. I wetted that out and then sanded it. Works great, but now I'm going to apply two-part epoxy barrier coat and some anti-fouling, as my new location in my club seems to be a mollusk-magnet...
But you were asking about the floors, weren't you? I agree: sand bare and then "encapsulate" in epoxy. Will last for ages.
Old 02-15-2007
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
I've done some research on doing the same for the plywood floor of our ten-year old inflatable - decided to use a two-part epoxy paint from Interlux:
Perfection
True Blue . . .
sold the Nauticat
Old 02-15-2007
moderate?
Ad...
True blue has it right if all you need to do is paint.
Advice refinishing teak and holly sole mcagney Gear & Maintenance 11 09-24-2009 07:03 AM
Inflatable Repair / Restoration (Zodiac, Achilles, Etc.) nauticalnut Gear & Maintenance 3 12-02-2006 02:45 PM
