Old 02-15-2007
sailor25b is on a distinguished road
Paint Stripper on gelcoat! Help!
No lectures please...
I made a mistake and used the wrong kind of paint stripper to remove the varnish on my handrails. I got a small amount of the stuff on the deck gelcoat where the rails are, and also had a small spill on the non-slip deck. I managed to wash it off quickly, but the solvent did eat into the gelcoat a bit, and sort of melted it.
It's hardly noticable, but I know it's there. The gelcoat still seems intact, just warped a bit. I wonder if I still need to repair the gelcoat. Or can I leave it alone?
Old 02-15-2007
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
If there aren't any gelcoat penetrations, the core should be fine - just a cosmetic issue. Try wetsanding the gelcoat with a very fine grit, followed by rubbing compound. Finish by buffing, after applying a good quality wax.
Otherwise - if only you know it's there, just leave it alone and live with it.
True Blue . . .
sold the Nauticat
Old 02-15-2007
tigerregis has a little shameless behaviour in the past
TB, you are the only person I have ever heard recommending wax on decks. Could you please explain your POV, since this the second time recently? Thanks.
Old 02-15-2007
TrueBlue's Avatar
Señor Member
My POV with fiberglass gelcoat is to protect and beautify the surface with wax . . . don't you wax your boat? The area in question was just "a small amount of the stuff on the deck gelcoat where the rails are . . . ". The section walked upon is covered in non-skid.
Of course my non-skid decks are teak - which I leave natural, but the solid glass everywhere else is waxed. Sorry for your confusion.
True Blue . . .
sold the Nauticat
Old 02-15-2007
hellosailor's Avatar
Gelcoat, even on decks, needs a sealant to keep out dirt, seal the pores, and protect it from UV degradation. That usually is wax or some fancy polymer.
Oddly enough, there are also "antislip" waxes that will increase traction. A very good thing to look for in a deck wax.
Old 02-15-2007
randy capedory 25d seraph
rtbates is on a distinguished road
Sorry to hear about your gelcoat. If you're interested there is a product that will remove any paint/varnish, does not effect gelcoat in any way and is water soluble. I used it to remove the painted name from Seraph's transom, as well as 8 coats of Cetol. Follow the directions and LET IT SIT till it turns white so it can do it's thing. Could take 4 hrs.
http://www.ibacktonature.com/Pages/aquastrip-PD.html
Old 02-16-2007
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
If it's pitted you can certainly prep it and fair in some gel-coat and then sand and polish smooth, the color match being the most difficult part of the job. If it's white you don't have to be too anal about the exact color as it will tend to fade and blend in.
Repairing Gelcoat Cracks and Chips Don Casey Gear and Maintenance Articles 0 11-06-2002 07:00 PM
Recovering the Shine Don Casey Gear and Maintenance Articles 0 08-04-2002 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Refinishing Gelcoat Don Casey Gear and Maintenance Articles 0 04-08-2001 08:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
