02-17-2007
Manufacturers seem reluctant to give out much information of use in troubleshooting... they'd rather you pay them to fix things.
Mike has good basic advice re: checking connections. Do the displays power up at all? if they read zeros then at least you know you're getting the power to them.
The speed impeller should produce some sort of pulse train when spun - but again specs are hard to come by.
As older instruments they may not be worth much, but in a way they are worth what it costs to replace them. Checking with the manufacturer makes sense, they can give you an estimate, or, you could put a cap on what you are willing to spend on repairs - often they will give a bit of a deal if you end up buying new from them after repairs are deemed not worthwhile.
