02-19-2007
With the blower in place as you described it's likely the boat was repowered at some point and initially had an Atomic 4 gas engine, for which the blower was essential. It likely wasn't used since the repower, hence the deterioration of the blower motor.
That said, using a blower on a diesel, while not technically required to remove potential explosive vapours, is not a bad idea. Pulling air from the engine space will minimize heat buildup and may also help to keep the inevitable diesel engine odours from permeating the cabin space.
Given that your cowl vents are likely atop the transom in typical Ranger fashion, I think the likelihood of serious water ingress is mimimal under normal sailing and weather conditions. Should you find yourself in extreme conditions it would be prudent to wrap/block the vents for the duration.
