These are long term maintenance and upgrades that really don''t resolve the original problem of the shaft moving in and out o fthe boat. Beyond that, I have couple thoughts here, I hope that he understands that he will need to realign the shaft very carefully after replacing the
engine mounts as there tends to be enough difference between old
engine mounts and new that you can be assured that the shaft won''t be properly aligned. (Going to a flexible coupler won''t eliminate the re-alignment problem.) He will still need to cut a detent at the setscrews to prevent his shaft from sliding out of the coupling.
