Old 02-25-2007
ABLiveSurfdotcom is on a distinguished road
Catalina 22 sliding hatch boards???
I'm looking for sliding hatch boards for my catalina 22. The ones I have now are worn, discolored, and weathered. I'm trying to find someone or someplace that carries hatch boards, and so far I have found nothing. Any feedback or help would be appreciated.
Old 02-25-2007
btrayfors will become famous soon enough btrayfors will become famous soon enough
You can buy almost ANY part for your Catalina 22 from:
Catalina Direct
10210 Systems Parkway, Suite 390
Sacramento, CA 95827
Tel 916-843-1970
They publish a comprehensive catalog, and are very nice and efficient folks to deal with.
Bill
Old 02-25-2007
CapnHand's Avatar
humble pie rat
CapnHand is on a distinguished road
Catalina Direct also has an on line store here: http://www.catalinadirect.com/
You can do a search for "crib boards" to find them.
The originals may be restored to "almost new" condition by sanding them down and refinishing. Otherwise they can be used as a pattern to cut new ones.
In either case, if you're not into the idea of a diy project, your local marina should be able to point you to a carpenter who you could hire.
If you decide to make new ones, wood is not the only option. Some are plastic and may resist the weather better than wood. I have seen some in clear or tinted lexan to allow more light inside. I have a set of screens made to fit that allow ventilation while keeping insects out.
There are 10 kinds of people. Those who understand binary and those who don't.
Old 02-25-2007
Goodnewsboy is on a distinguished road
Be of good courage. I am cheap, so will advise you to try refinishing.
Get the old finish (if any) off the wood. Use a stripper to minimize unnecessary wood loss from sanding.
Assuming they are teak, start with some good teak cleaner, then rinse thoroughly and let dry. This should remove black stains.
Sand them with #120 grit sandpaper and a sanding block, or use a vibrating sander, try to get back to clean looking wood. You may be limited in the amount of sanding you can do if your are dealing with plywood. Don't sweat it, get the surface as smooth as you can without breaking through the finish ply.
Finish sand with # 180 or 220 sandpaper
Using a good grade of exterior spar varnish, brush (foam or natural bristle) on a first coat thinned a little with turpentine. Follow with about 8 additional un-thinned coats, rubbing down with scotchbrite or 220 grit sandpaper between coats. Wipe down thoroughly just before applying new varnish.
Perfection may not be achievable, but they will look a lot better.
Add a couple of coats each season.
Old 02-25-2007
Thanks for the help!
Old 02-26-2007
SailinJay is on a distinguished road
You may have already called Catalina Direct, but they have a toll free number as well as the one already posted. It's 1-800-959-7245.
Old 04-21-2010
dadzigian is on a distinguished road
At Catalina Direct you can buy crib boards or go to catalina22experiment to see how to build your own teak crib boards as well as many other projects in my project gallery.
Old 04-21-2010
doubt they much care, as they needed the boards three years ago... and probably have already found new ones.
Sliding hatch question. C27Shockwave Gear & Maintenance 3 12-21-2006 08:17 PM
Wood vs. Plexi - Companionway Hatch Boards lightyear22 Gear & Maintenance 7 03-16-2006 09:06 AM
Need new hatch boards in DC FRRizzo111 Gear & Maintenance 1 04-06-2005 08:29 PM
Hard to Open Sliding Hatch sjacovino Gear & Maintenance 6 02-13-2002 07:29 PM
Replace or Refinish Hatch Boards Sue & Larry Gear and Maintenance Articles 0 07-06-2001 08:00 PM
