Old 02-27-2007
1970Columbia34's Avatar
1970Columbia34 is on a distinguished road
Send a message via AIM to 1970Columbia34 Send a message via MSN to 1970Columbia34 Send a message via Yahoo to 1970Columbia34
Navigation Lights
Were are re-wiring our mast and was reading the the newest Good Old boat about navigation lights, my orginal plan was to remove the fwd facing masthead light that is half way up the mast and switch to a top of mast light that has the choice of just the fwd half on or all around on for while at anchor. And the usual red, green and white stern light. What should I do keep the mast head light half way up the mast and just all around light at the top or switch to the combo light at the top. Thinking of using this light... http://www.starmarinedepot.com/detai...duct_id=PE1828
Scott
Old 02-27-2007
taandel is on a distinguished road
Scott:
I use the light that you have shown as your choice and installed it in 2002. I like both being at the top of the mast as i can see the top of the mast at night and be comfortable with bridge clearance, etc.
Of course, the other thought is that if the mid-mast running light works for you, why go thru the trouble and cost of changing?
Tim
Tim
Old 02-27-2007
Well the re-wire is the biggest cost and that light is only $24 so the cost is not the big factor, I more or less want to do it right while we have the mast down.
Old 02-27-2007
Valiente's Avatar
Just as a side point: my Windex has a little light on a separate circuit that casts a surprising amount of light at the mast top, but isn't readily visible from the dock.
It's interesting to see a "tri-colour" thread that doesn't include the words "expensive" and "LED" and "COLREGS approved".
Old 02-27-2007
The mast spreaders each have a light that shines down on the deck to give you working light if needed. I thought about the Tri-color but wow, I will stick with the good old version of boat navigation lighting.
Old 02-28-2007
trantor12020's Avatar
trantor12020 is on a distinguished road
I believe there's Colregs on use of tri-color with boats of certain length. you'll have to check to see your other modification comply with Colregs.
Old 02-28-2007
Ronbye's Avatar
Ronbye is on a distinguished road
That forward facing mast light half way up the mast is often referred to as a steaming light. It must be on when you are motoring at night. I stand to be corrected, but you not allowed to have a steaming light at the top of the mast. There are some mfgr's out there that make a combination steaming light and deck light in one unit. I have one. I would not move the steaming light up to the top.
Old 02-28-2007
txmatt's Avatar
txmatt is on a distinguished road
Doing a quick search on Lord Google, I found this which is in line with what I recall reading before:
http://www.auxetrain.org/lights2.html
Is this incorrect? I plan to install a combination masthead/anchor light at the top of my mast before I launch in a couple of weeks. From the pictures on that site it seems that the top of the mast is fine.
Matt
Kittiwake 23
Old 02-28-2007
so as this reads http://www.westmarine.com/webapp/wcs...1/navlight.htm
Old 02-28-2007
pigslo's Avatar
pigslo is on a distinguished road
Have you considered LEDs as they are getting better, cheaper, and are misers for electricity?
pigslo
Working With the Stars—Celestial Navigation Jim Sexton Seamanship Articles 0 05-06-2003 08:00 PM
Working With the Stars—Celestial Navigation Jim Sexton Her Sailnet Articles 0 05-06-2003 08:00 PM
Navigation Basics Jim Sexton Learning to Sail Articles 0 01-04-2002 07:00 PM
Navigation Basics Jim Sexton Seamanship Articles 0 01-04-2002 07:00 PM
Navigation Basics Jim Sexton Her Sailnet Articles 0 01-04-2002 07:00 PM
