03-02-2007
In 1996, I added a new vhf cable up the 54' mast of my boat, before heading to Mexico. Since I do not have internal halyards, that was not a problem, I simply dropped a weighted line down from the top, and pulled the cable up from the bottom. To secure it, I picked up the cable through the motoring light opening, a deck level wire outlet, a spreader opening, and through one or maybe two holes from which I had removed the machine screw holding the schaffer sail track to the mast. the support medium was Nylon "Mule Tape", which I supported in different creative ways throu the holes. Some of the details of this, I don't remember, but I do recall trapping the tape under the gasquet under the motoring light at the bottom. On the mast track hole(or possibly two), I melted the tape into the flathead screw recess, and screwed in a smaller flathead self tapping sheetmetal screw. Very Rube Goldberg overall. This is generally regarded as not sufficient support, but it has worked fine for over 10 years and at least 10,000 miles at sea.
