03-01-2007
You definitely want some sort of protective covering over the cut edges of the mast, to protect the cabling... either a grommet or bushing of some sort. Make sure that it will fit over the cable fittings, if you have installed them before running the cable. Generally, I recommend that you run raw cable and then attach the fittings afterwards, so that you can minimize the size of the holes you have to make.
