02-28-2007
Shaken-not Stirred
Connectors
As was stated, the aluminum connectors are very resistant to corrosion from salt, etc. due to the alclad coatings and a heat cured zinc chromate coating. There are stainless steel connectors at the higher end of the spectrum but brace yourself for the cost.
Many of the connectors are of course specifically designed for what you're going to use it for and you can even get connectors that are essentially hermetically sealed once engaged. Way Expensive.
The necessary (usually rubber) gaskets are supplied with the unit. Especially in the bulkhead type connectors. (Caution! Tiny screws and nuts involved)
There is a company in Roanoake, Tx by the name of BASCO that deals with these connectors. I don't have a number for them considering where I'm at right now but they should have a website.
A popular but expensive connector that goes by the brand name of HiRel should also be looked at for comparison. You probably won't want to use it but it will round out your knowledge of connector extremes.
Many bulhead connectors also come with a cover that has a lanyard to the plug base. When the mast is off and the connector is disconnected, the deck pass-through side can be covered to prevent water pooling, damage, etc.
Good Luck!
Opportunity is missed by most people because it is dressed in overalls and looks like work.
T.A.E.
