fresh water tank maintenance - SailNet Community
post #1 of 2 Old 01-07-2002 Thread Starter
Does anyone have thoughts on whether it makes sense to epoxy or otherwise coat the bottom of my recently removed aluminum fresh water tank before I reinstall it in wooden blocks in the bilge? Thanks for your advise or experience.
wrguest is offline
post #2 of 2 Old 01-07-2002
A recent article in National Fisherman says to bed in plastic, neoprene, etc., but AVOID contact with rubber, wood, FOAM, blah, blah, blah. While the argument that "everyone does it" is not generally the way to go, I just installed new tanks in a Grady White 25 and a Wellcraft 26. The Grady tanks were minimally foamed ("GREAT STUFF" spray insulation foam) and wedged with 2 x 4''s and strapped with boards across the top. The Wellcraft tank was a replacement, 120 gal alum custom made. We foamed the corners to avoid a hard edge against the hull (like the original tank had) and foamed spots all around and will finish with tie down boards with rubber under them across the top of the tank. It''ll last a good 10 years if properly grounded. Amazing what these manufacturers do. Anyway, we also coated the entire tank with GLUVIT, an epoxy specifically for tanks. Keep the moisture off and avoid spots where moisture can accumulate and sit. Get the Nat''l Fisherman newspaper if you want a truly tight-assed approach to tank installation, which, in fact, I might use on my own boat (unlike the factory installations in the foregoing two manufacturers).
VIEXILE is offline
removing orig water tank zeilfanaat Gear & Maintenance 8 03-28-2017 12:26 PM
Fresh water tank slime pearsalls2 Gear & Maintenance 15 09-09-2009 02:36 PM
Osmosis in integral FG water tanks sailawaysteve Gear & Maintenance 4 11-28-2007 10:10 PM
fresh water tank, tastes like ****! nauticalrich Gear & Maintenance 6 05-24-2002 04:17 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 05:59 PM
