replace halyard - Page 2 - SailNet Community
post #11 of 53 Old 03-01-2007
paulk's Avatar
Have to agree with Mitch on this one. Changed two of our wire/rope halyards to all line five years ago and have had no problems with sheaves. The new hi-tech synthetic lines so strong that if you wanted you could use an all-fiber line that was thinner than the original wire was, and it would stretch less than the wire did. Our halyards are 5/8" simply because thinner stuff would cut into the crew's hands too easily. Though the "super-plastic" line is not cheap, it ends up costing less because 1/there's no rope/wire splice! 2/ you can tie the halyard shackle to the end of the line 3/ you can end-for-end the halyard in a few years if it starts to get worn, and double the useful life of the halyard. (Ours has been in place five years and hasn't needed to be switched end for end yet.) It's not complicated to do (as Giulietta says) and the sheaves at the top, if they were set up for wire, are probably relatively large diameter sheaves that will work well for the new high-tech lines.
paulk is offline
post #12 of 53 Old 03-01-2007
SD-
"Yes, but if you've done a poor job of taping, "
Well, just for you, we could have someone glue 'em up with 3M 5200 overwrapped with plain cotton bandage gauze and let it harden up for 48 hours before pulling it through. No way that baby's gonna come apart until someone cuts it.
hellosailor is offline
post #13 of 53 Old 03-02-2007 Thread Starter
Smile re: replaving halyard
Thanks for all your thoghtful suggestions. I appreciate all the options that you've given me.
dogmandave is offline
post #14 of 53 Old 03-02-2007
Actually, the wire still stretches less than even the best of the high-tech lines—wire stretches only about 1%—the high-tech lines go about 1.5% to 5% or so. Most of the newer high-tech lines have pretty poor knot holding capability, due to the materials they're made from, and should be spliced, not tied.
Also, kind of curious as to what size boat you have, if your halyards are 5/8" is diameter... which is the size of the anchorline I use...
sailingdog is offline
post #15 of 53 Old 03-02-2007
Senior Moment
SailorMitch's Avatar
Yes, but if you've done a poor job of taping, and hauled too hard going up...you're likely to end up going up the stick.... and doing it my way avoids almost any risk of that. You can work smart or you can do a half-assed job of it and get screwed for it.
Dawg -- Your basic assumption is that you have to replace a wire/rope halyard with the same thing. That may not be the case. Absolutely nothing half-assed about my approach, which has never failed me when replacing halyards, or even removing them to clean them or whatever. So let me work stupid and be happy about it.
Of course, feel free to do it your way. You will anyway -- and I don't care! You're always right. Uh huh.
SailorMitch
Sailing winged keels since 1989.
1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
SailorMitch is offline
post #16 of 53 Old 03-02-2007
Owner, Green Bay Packers
Gotta bark with the dog on this one.
While the sheaves (and could we please eliminate the word pulley from this site) may be of sufficient diameter the issue is the width of the sheave. Regardless, we know that as we reave the line the point at which it is going to be toughest is as the line passes over the sheave. That's where we're going to give it that little extra tug. Then three things can happen, two of which are bad. First: the sheave is of appropriate size and the line goes over and works just fine. Second: the sheave is of inappropriate size, the line goes over, and proceeds to either foul or abrade severely as we employ it in sailing. That could be dangerous if discovered while trying to lower the sail in an emergency-or could make an emergency out of a routine operation. Third: The new line fouls at the truck and we have to climb the mast anyway.
All in all, the dog's suggestion really has no down side. Running all line without knowing what is actually at the truck in the way of a sheave is sort of like landing a shark in a boat. If you're not sure that he is real dead, you might want to consider a Plan B before he's actually in the boat.
sailaway21 is offline
post #17 of 53 Old 03-02-2007
Actually, most people do replace a halyard with the same kind...and the OP didn't indicate that they were going to be going from a wire-to-rope halyard to an all rope halyard. If you make the assumption that they are changing to an all-rope halyard, you're making a much bigger assumption than I am... since I'm basing my assumptions on the OP's post. While I haven't seen how you "tape" your halyards together, I've seen too many piss-poor taping jobs end up with someone having to go up the mast to recommend it. If you feel you're working stupid...be my guest—but it does sound like you've had a fair bit of luck on your side as well.
post #18 of 53 Old 03-03-2007
Here .. Pull this
If your boat is not too big or too heavy, then just pull it way over on it's side (as if it were heeling a lot - put your centreboard up first). You might be able to use your jib halyard - again depends on how big the boat is. Put a ladder under the tip of the mast and change the halyard.
If the boat is too big then buy a bos'n chair and do it properly, you're going to have to go up there eventually, so you might as well get used to it while things are nice and calm at the slip. If you get nervous up there I find it helps to think about beer.
If you go from wire/rope to all rope, make sure that the rope you use does not have any stretch. The reason that there is wire there to begin with is because rope stretches until it falls apart. There is probably something on the market now that doesn't - have not investigated this for a long time.
The third option is to find a willing student and pay them fifty bucks to do it.
Sailormann is offline
post #19 of 53 Old 03-03-2007
Senior Moment
Cool
Most people I know who replace a wire/rope halyard want to go to all rope, if their sheaves allow. An all rope halyard has many advantages over the old wire/rope. And despite your claim, there are many ropes out there that stretch 1 percent or less. One problem with wire halyards is that the riggers often use a rope that is easy to splice to the wire, and that also usually is quite a bit stretchier than the wire, so you lose that property of the wire to a degree anyway.
To be fair to the original poster -- assuming your instructions are accurate -- you also should tell him that your method will require cutting off the current swage fitting and shackle to get the old wire out of the mast, and then he will have to swage on a new fitting for the shackle once the new halyard is in place. He might like to know that going in.
And once the swage and shackle are cut off the current halyard, how do you propose to tie the messenger line to the wire so that you have a knot small enough to fit through that tiny sheave?
As for my working stupid, you made a previous statement along the lines of "work smart and do it my way." Thus, your implication was that my way was working stupid. I was only stating what you implied, with a tad of sarcasm of course.
As always, YMMV.
SailorMitch
post #20 of 53 Old 03-03-2007
The messenger line I'm using is braided, and I will put the braid over the wire and then whip it to the wire, several times over the distance of about a foot. Done properly, this is very unlikely to let go, and goes through the sheaves very smoothly. There is no knot, and very little bulk to this type of connection. If you're really paranoid...a drop or two of cyanocrylate adhesive will make sure it doesn't move.
Tale of the stuck halyard wlcoxe O'Day 0 08-23-2006 04:45 PM
Another lost halyard... pluscard Gear & Maintenance 13 06-26-2006 05:40 PM
halyard working load Randolph Bertin Learning to Sail 1 10-27-2003 11:12 PM
main halyard Sailmale Gear & Maintenance 5 06-20-2002 09:25 PM
Rereaving the Main Halyard Dan Dickison Racing Articles 0 02-11-2002 07:00 PM
