03-02-2007
Location: Ft. Lauderdale, FL currently CLODs [cruisers living on dirt]
Most dual hull RIBs get water between the two hulls. Mine does as well, all you need to do is while it's out of the water pull the second drain plug and out it comes -- works better is bow is higher. I do this every so often and it has never been an issue.
I think most of the water comes from the joint between the hulls where the tubes connect - but can't say for sure - cause there is water in the hulls after a really heavy rainfall.
Jon D
SV Sirius
Moody 47
