Old 03-04-2007
Jotun's Avatar
Space cadet
Jotun is on a distinguished road
Thru hull stuck
The thru hull for my raw water intake is stuck in the open position. I don't want to turn it too hard for fear of breaking it. Any suggestions? Should I just leave it alone?
Old 03-04-2007
Idiens's Avatar
Larus Marinus
Idiens is on a distinguished road
Try a six-pack? No sorry, wrong question.
Definitely don't leave it alone. If one of the engine hoses gets leaky, you could have water everywhere. What sort of valve does it have? Ball valve, gate valve?
Old 03-04-2007
divy is on a distinguished road
I had same problem, heated it up with blow tourch,just to hot, not red hot, friend held fire extinguisher.
Old 03-04-2007
I forgot to say to tap it lightly with a small hammer.
Old 03-04-2007
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
If it has a square head on it, often with a line or arrow on it, and opposite of that square head is a locking nut you have what is called a square head **** or alternatively, a throttle valve. These are made of brass or bronze and can be just a bundle of fun to turn after they've set a while.
First off you need to back off the locking nut on the bottom of it until it is past flush with it's threaded shaft. You are going to beat on that nut and you want to protect the threads from your hammer blows. Start out tapping on it firmly. Then try to turn the square head with a large crescent or open end wrench. You should 'backwrench' the valve while trying to turn it open. Backwrenching merely is the placement of a pipe wrench on the valve, or adjacent plumbing, and creates a force in the direction opposite to which you are trying to turn the valve. In addition to giving you leverage, it prevents your torque from snapping off the thru-hull or something else. The valve itself is heavily constructed and should not break.
What you are turning inside is a tapered plug with a slot for an opening, and the nut when drawn up tight pulls that taper down into the valve body and that is what makes it so tough to re-loosen. Pounding against the nut should be oppossed by a ballpeen hammer on the opposite side of the valve, off the square head, in much the same manner as backwrenching, to limit the transfer of your blows power and confine it to the valve. You can heat it with your torch if it is not full of water. When heating with the torch, whether full of water or not, be mindful of heat transfer to adjacent fittings. Fiberglas and most marine sealants do not take kindly to high heat. It often takes a pretty good rap to get these to move, and sometimes removal of the entire valve, and placing it in a vise is the easiest thing to do.
While apart you can silicone grease the inside of the tapered plug, but it will probably be just as tough the next time. Tighten the nut to the point only that the valve does not leak. Better yet, replace the valve with a ball valve or butterfly valve. These turn freely and, in fact, I recommend removal of their handles to avoid inadvertent closing/opening. The handle can be secured to the hose adjacent to it's valve with a scrap piece of wire.
If you have a gate valve, you may be able to remove the packing nut first, and then the bonnet, to extract the gate and examine and lube it's threads. You will probably want to replace the gate valve, even if you get it to work. Gate valves have gotten a bit of a bum rap of recent. A top quality gate valve has a threaded shaft that actually protrudes out through the valve wheel. This feature keeps the working portion of the shaft out of the fluid the gate is in. It also offers little resistence to flow. Most lesser quality gate valves have the threaded shaft internal to the valve and they set up, break, jump a thread, and impede flow. Other than that they are fine! lol Most gate valves get damaged, in fact most all valves, by over-tightening. You can warp the gate or jump a thread easy enough. They can be quite serviceable if you "exercise" them monthly by opening and closing once or twice. Since nobody ever does that their most oft found position is stuck open, closed, or the always useful closed but leaking profusely. When replacing you will find that a quality gate valve will often exceed the price of a decent ball valve, and be more in the price range of a butterfly valve.
I am not a fan of square head cocks. If for some reason you need to close it in an emergency you will invariably find it set up, and you without the time to be monkeying around with it. They are not cheap either.
Old 03-04-2007
Jotun's Avatar
Space cadet
Thanks for all the great replies. I should have mentioned that the seacock is a plastic ballvalve, which means no heat for sure. I am hesitant to even use a small hammer on it.
Old 03-04-2007
Then don't worry about operating it-get rid of it.
Old 03-04-2007
redcorvette1995 is on a distinguished road
Take boiling water in a kettle and pour it on the seacock. Repeat until it moves. It will not melt the seacock, but it will probably let you move it.
Replace the seacock / valve ASAP.
If it is one of the better plastic marlon valves then rather than replace it you can get a rebuild kit.
Cheers,
Todd
Old 03-04-2007
Jotun's Avatar
Space cadet
If I replace the seacock do I have to replace the thru hull too?
Old 03-04-2007
If the through-hull is marelon, then you'll probably want to use a marelon seacock with it... if the through-hull is just plastic...get rid of it...
If you want to replace the seacock with a bronze one, you may want to replace the through-hull with a bronze one as well.
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
Spring Hull Cleaning Tom Wood Gear and Maintenance Articles 0 04-05-2004 08:00 PM
New Shine for an Old Hull Don Casey Gear and Maintenance Articles 0 01-08-2002 07:00 PM
Hull Speed Demystified Steve Colgate Learning to Sail Articles 0 06-10-2000 08:00 PM
Hull Speed Demystified Steve Colgate Buying a Boat Articles 0 06-10-2000 08:00 PM
