New thru-hulls/seacocks - Page 2 - SailNet Community
post #11 of 28 Old 03-05-2007
pigslo's Avatar
I'll weigh in. One of the reasons to use a seacock with a flange is the additional support if stepped on. I did mine with a block of wood with holes drilled and then three coats of polyurethane absorbed at the edges makes the wood like a peice of plastic. I then bed the whole thing in 5200 and cover the countersunk bolts if fiberglass and fair it. It helps if your hull is an inch thick in most places that a thru hull would be.
pigslo
pigslo is offline
post #12 of 28 Old 03-05-2007
5200 or 4200 seems sufficiently adhesive to Starboard backing plate in that application. No nut should be installed between the seacock flange and the plate. Instead, dryfit the thruhull fitting and mark for cutting. Before cutting, thread the nut all the way on, and after cutting "clean up" the threads at the site of the cut by unthreading the nut off the thruhull.
roywmoss is offline
post #13 of 28 Old 03-05-2007
Originally Posted by camaraderie
Dawg...right...actually I think mine are balsa or something like that...much lighter than pine.
I thought you were talking abou the through hull being screwed. I agree about the sea-**** flange to the starboard or wood backing plate...not into the hull. How do you affix starboard to the hull...I thought nothing like 5200 would stick to it?
You could glass it into place...but that's a bit overkill. I think that both 5200 and 4200 will stick to it...but I'd have to check compatibility... I would probably go with 4200 if it won't dissolve the starboard.
What I have been using myself is solid fiberglass held in place by a bed of thickened epoxy. I had some 1" thick fiberglass panels left over from something a friend of mine was doing...and just chopped it into 4"x4" squares and 4" wide strips...
sailingdog is offline
post #14 of 28 Old 03-05-2007
pigslo's Avatar
Fiberglass panels would work great if you got them. One of the advantages of wood is it can easily be shaped with a belt sander to match the curve of the hull.
pigslo
pigslo is offline
post #15 of 28 Old 03-05-2007 Thread Starter
ereuter's Avatar
So are you advocating using the valve AS the nut in the final installation? It seems that if there is a nut between the flange and the block of wood, it would make the screws a bit unstable.
Eric
ereuter is offline
post #16 of 28 Old 03-05-2007
Eric
Actually, he is recommending that you use the nut to figure out how short to cut the threaded shaft of the thruhull, and that you use the nut to clean up the threads after cutting the thru-hull shaft. He isn't saying you should use the nut and the seacock though.
post #17 of 28 Old 03-05-2007 Thread Starter
ereuter's Avatar
Right, but someone DID suggest using the nut and the seacock together in an earlier post, if I understood correctly.
This is all great info. Thanks for all the responses. I have a feeling that this is one of those jobs that is terrifying to someone who hasn't done it before, but isn't really a big deal.
I ordered all my parts today, so I'll probably get at it in a week or two if the weather warms up enough.
ereuter is offline
post #18 of 28 Old 03-05-2007
Yes that was me... I generally have a routed out hole in the fiberglass backing block, so the nut can be seated and not interfere with the seacock sitting on the block. The fiberglass blocks I use are pretty thick... about and 1" or so.. I probably should have clarified that earlier... if you don't have a routed out block to accept the nut and let the flange sit flush... don't use it...
post #19 of 28 Old 05-05-2007 Thread Starter
ereuter's Avatar
I finally had a chance to pull my old thru-hulls out today. I was surprised to fine that the hole in the hull is about 1/4" larger in diameter than the fitting. Is this normal? Seems like a lot of space to fill with sealant.
I'm going to pick up some starboard in the morning, and hope to get the new thru-hulls and seacocks installed tomorrow.
Thanks,
Eric
ereuter is offline
post #20 of 28 Old 05-06-2007
That hole seems to be oversized from what I would have expected. Does the outer flange of the thru-hull seat properly and give you sufficient surface contact. It might be worthwhile to fill the hole with thickened epoxy and then drill out a proper sized hole in the center of it. At least, that would be what I would do.
