New thru-hulls/seacocks - Page 3 - SailNet Community
post #21 of 28 Old 05-06-2007
What type of seacock, or proper ball valve, would you recommend to go with the through hull?
Northeaster is offline
post #22 of 28 Old 05-06-2007
Freesail99's Avatar
The large seacock for my head is frozen. I tried to remove it for a couple of hours today. I couldn't stop the thur hull from turning. The area is to small to get a good grip with a second wrench. Any Ideas ?
S/V Scheherazade
Freesail99 is offline
post #23 of 28 Old 05-06-2007
There are usually two tabs inside the thru-hull so that you can hold them with a special tool designed for that purpose. You can use the handle of a wrench (pick a size that fits tightly inside the thru-hull) instead and put that inside the thru-hull and ask someone to hold that on the outside while you turn the valve from the inside. If that doesn’t work I just cut slots in the flange of the thru-hull with the edge of a grinder and break the pieces off. Then pull the thru-hull and valve out on the inside of the boat.
All the best,
Robert Gainer
Tartan34C is offline
post #24 of 28 Old 05-06-2007
A flat piece of steel, the width of the diameter of the thru-hull, maybe 1/8" thick and two inches long, can act as a "wrench" and if you attach a set of vice grips to it... someone can hold it and prevent the thru-hull from turning.
sailingdog is offline
post #25 of 28 Old 05-07-2007 Thread Starter
ereuter's Avatar
Well, the job is done, and wasn't bad at all. Although one of the holes was slightly oversized, it wasn't the 1/4" that I thought.
I ended up using 1/2" Starboard for backing blocks, and everything went together nicely. Plenty of 5200 everywhere. It may never come apart, but I don't expect any leaks either.
Thanks for the advice and encouragement.
Now to paint my naked hull...
Eric
ereuter is offline
post #26 of 28 Old 05-07-2007
Freesail99's Avatar
posted in the wrong place
S/V Scheherazade
post #27 of 28 Old 05-07-2007 Thread Starter
ereuter's Avatar
"Gear & Maintenance" seems to be like the appropriate place for a discussion of thru-hull replacement. Where would you suggest it be?
ereuter is offline
post #28 of 28 Old 05-07-2007
Freesail99's Avatar
I posted in the wrong place and I removed my post. Sorry for the confusion.
S/V Scheherazade
