Newport 41 Prop Shaft Diameter - Page 2 - SailNet Community
post #11 of 12 Old 03-06-2007 Thread Starter
I don't discuss my member
Fstbttms's Avatar
Originally Posted by Tartan34C
Fstbttms,
Shaft material does make a difference. But in the real world most boats of similar size have similar engines and with a limited number of available sizes it doesn’t vary much. But it will matter in some cases. By the way its stiffness not strength that makes the difference.
I guess I'm not understanding your point. Are you simply pointing out the differences in strength/stiffness between prop shaft materials or are you saying Newport 41 "A" is likely to have a different shaft diameter than Newport 41 "B"?
Fstbttms is offline
post #12 of 12 Old 03-06-2007
I think he is saying that it is unlikely that the Newport 41 is going to have a shaft diameter other than the standard 1-1/8" but that it is possible that it could. Unless the boat in question was re-powered and had the shaft changed out...it will most likely be 1-1/8" as you've said.
sailingdog is offline
Changing prop underwater trantor12020 Gear & Maintenance 16 03-03-2007 12:02 PM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Drive Train Vibration Tom Wood Gear and Maintenance Articles 0 10-10-2002 08:00 PM
prop shaft thomasstone Gear & Maintenance 3 03-27-2002 03:03 PM
prop shaft coupler thurston Gear & Maintenance 2 12-31-2001 06:00 AM
