Old 03-07-2007
AquaVitae is on a distinguished road
Electric Cables in the mast.....
Hi
I am just about to install a TV aerial and a "See Me Radar" transponder and need to run cables for each inside the mast. The boat is a Jeanneau Sun Odysessy 40 and I was wondering if there were any special ways I need to approach running cables inside the mast and advice people can give me from their experiences.
Is it was a case of fitting a grommet top and bottom and pulling the cable through or are their special things I should be doing??
Sorry if this is a daft question.
Old 03-07-2007
k1vsk will become famous soon enough
Depending upon the year of the Jenneau, there may be a conduit with space available already in the mast through which the new cables can be run which results in less chafe and noise. Easier if the mast is down.
Old 03-07-2007
You should probably run the cables inside a conduit inside the mast, if there is one.... if not, it may be a wise idea to install one while you're doing this...as it will simplify future wiring and help protect the wiring and the halyards with in the mast from chafe. It also can reduce the noise from the cables moving inside the mast and reduce the chance of the wires breaking from work-hardening and fatiguing.
Old 03-07-2007
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
I would search the past threads on this topic as well. Much has been written on it. Welcome.
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 11:06 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
