03-07-2007
I've heard good things about their equipment... and anything that uses OTC parts is an improvement over things that use proprietary parts.
Be aware that all RO watermakers have some serious limitations on where and when you can use them—polluted waters, waters with high-bacteria counts, and waters with a lot of sediment are generally not good places to use them...so many anchorages are not ideal.
Chlorine can destroy the membrane in a watermaker, and ideally, if you need to back flush your water maker's membrane, you should be using RO water to do so.
Sizing the watermaker is also something to look at... often getting a slightly bigger watermaker is going to be more efficient in the long run than a smaller one. On my friend's boat, she runs the watermaker once every two or three days rather than every day since she got a larger watermaker. This ends up being much more efficient, since the amount of water, percentage wise, that is required to flush and maintain the watermaker is much lower...as is the amount of electricity used.
I do not have a watermaker on my boat... and don't envision installing one anytime soon, as the waters I sail in don't really require me to have one.
