03-07-2007
You probably want a larger panel than that, especially if you're going to be using the batteries at all.
Figure out what your electrical use will be...by multiplying the amps required * hours used, for the running lights and stereo and then size the panels accordingly.
Something like this will probably do the job for you, given the three-days of sun average...but you don't want to be running the battery down to empty, as this will drastically shorten its lifespan.
Batteries on boats should only be used to 30-50% of their capacity. Using them more drastically starts to shorten their usable life.
You really need to do an electrical budget, and scale your battery bank to be about 2-3x the expected draw of your use period between chargings.
