03-07-2007
I agree, most of the spreaders I see do bisect the shrouds.
As Robert has stated, if the spreader doesn't bisect the angle of the shroud, the forces on the spreader aren't inward, along its length, but will tend to rotate it...and the more it rotates, the stronger the forces will be... eventually the spreader will collapse...and then there goes the mast. Most spreaders have little strength to resist any torsion, and really only have strength in compression. Many newer spreaders have a "lock" that tightens down on the shroud, helping keep it positioned properly.
