Blogs
User Name
  #501 (permalink)
Old 04-03-2007
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enoughhellosailor will become famous soon enough
I remember reading about another "exciting new breakthrough" that would revolutionize solar because of new high outputs, vaguely something about research from South Africa. And, curiously enough, investment links.
Not that it was an investment scam...that I know of...but it was supposed to be "imminent" and of course, somehow it just never quite has happened yet.
Reminds me of the spams for hot new petroleum investment opportunities that used to go around.
About DOE ratings? I'm sure you can find those with a web search srilling down through Department of Energy - Homepage.
In the meantime:
From AM Solar - Solar Panels
"How they are rated.
Panels are rated in Watts of output. This wattage rating is derived by multiplying the panels peak power voltage times its peak power amperage (Watts = Volts x Amps). These ratings are based on standard test conditions (STC) of 1000 watts/square meter of light input, a cell temperature (not air temperature!) of 25 Degrees C (77 Degrees F), and an air mass of 1.5 (slightly above sea level).These standard test conditions are rarely found in "real world" operating conditions. For example:
1000 watts/square meter of sunlight would only be reached around solar noon, with the panel squarely facing the sun, just after a rain shower has washed all the dust out of the air. [Emphasis mine] "Real world" input is usually around 800 to 850 watts/square meter on a bright day (when you factor in dust and air pollution and consider that the panels are laid flat on the roof and are therefore not square to the sun).
When you consider that solar cells are dark blue to almost black, they soak up sunshine and get quite hot so they are operating at temperatures considerably higher than 25' C (77' F). This increased cell temperature translates into a voltage drop and therefore less output.
The air mass changes as you move from sea level to mountaintop. The atmosphere is thicker at sea level so more sunlight is interrupted by dust and pollution and less gets transformed into solar electricity. Conversely, the same panel operating from a mountaintop will see more intense sunlight and will produce more power.
This is not to imply that panel manufacturers are purposely trying to deceive you. It is because "real world" operating conditions are so variable that they had to come up with some standard test conditions so that all panel ratings "
  #502 (permalink)
Old 04-03-2007
sailingdog sailingdog is offline
sailingdog is just really nicesailingdog is just really nicesailingdog is just really nicesailingdog is just really nice
And some people were wondering why we were scoffing at daily outputs that seemed to require perfect output from the SolarStik panels. I've seen how hot the solar panels can get, and mine run relatively cool, since they have a huge airspace beneath them and around them.
Add in the atmospheric dust, air pollution, imperfections in aiming them... and it isn't any wonder why anyone should doubt any results claiming to get more than 100W output from 100 W solar panels.
If you're new to the Sailnet Forums... please read this POST.
  #503 (permalink)
Old 04-03-2007
Hey, SD, I've got a "Solar Cup" I can sell you. It consists of a rugged mounting pole with one 50-watt rated solar panel on it, and a ten foot diameter mirrored parabolic array that concentrates sunlight 10x on it, so I can get 500 watts out of it.
Now, you're going to protest that's impossible because the heat would make the panel combust, but we've thought of that too, there's a neat liquid-nitrogen cooling tube array integrated into the bottom of the panel, and you can buy liquid nitrogen refill cartridges from us anytime you need them.
Now look what you've done, my Evil Twin Brother has jumped in the thread!
Sponsored Ad
  #504 (permalink)
Old 04-03-2007
HS... let me guess.. the solar panel cup powers the compressor for the liquid nitrogen cooling system and only uses 450 Watts of power to do it..
  #505 (permalink)
Old 04-03-2007
captainchetco captainchetco is offline
captainchetco is on a distinguished road
Real world experience: Two friends of mine have just passed through the Suez Canal after sailing in the Pacific since 1997. They have two fixed mount solar panals on the coach roof, subject to frequent shading... I belive they are 1995 vintage 100w Siemens, but may be Arcos. They also purchased two 40w Unisolar flexible panals. For over 7 years, they actually got more power from the Unisolars, because they would move them to whatever location was unshaded.
The Unisolars were delaminating (i think both, but maybe just one) and their output was dropping. They wanted 3 more to replace them, but alas, Unisolar had gotten out of the consumer flexible panal business, and were no longer available. They bought a wind generator.
  #506 (permalink)
Old 04-03-2007
A question I should have asked before? What is the state of the flexible panal industry & approach now?
  #507 (permalink)
Old 04-03-2007
WaterHouse WaterHouse is offline
WaterHouse is on a distinguished road
My complaint
After reading 51 pages tonight while getting some chores done, i must register my complaint. I've lurked here more than a year, learning a lot, sad to post this.
This site is becoming like sailing anarchy. A newcomer says something that causes a frequent poster to make a personal remark, a fight ensues, and several join the fight to defend their comrade, while other frequent posters try to hijack the thread because everyone is embarrassed.
After a year, i see a trend of more of the above. Tell me that i'm wrong. I still have a lot to learn, and this is still a great place. I hope it stays that way.
I think you can tell someone you think they're a shill with better manners, and certainly less adjectives. How many fights have you been in? Why?
My newbie vote is for higher standards.
  #508 (permalink)
Old 04-03-2007
SimonV's Avatar
SimonV SimonV is offline
Back in Oz
SimonV will become famous soon enough
[color="Red"]I have read this tread more than once.
[color="Purple"]Could some one tell me should I spend $1200 on a wind generator or $850 each for a 120w solar panel would need 2.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Moreton Bay Queensland
YACHT BROKER
  #509 (permalink)
Old 04-03-2007
SimonV-
It depends... most boats are best off with a mix of wind and solar, since sunless days often have wind, and some sunny days have no wind. It also depends on what boat you're on. A smaller boat may be better off with two solar panels, if they can find a reasonable way to mount them. Wind generators need to have clearance so that they don't chop the crew in to chum... A larger boat, which generally has a larger electrical bank and higher electrical demands will usually be best off with both, and you can usually accommodate both on it.
Is the area you sail in normally sunny, then get the Solar Panels. If not, then go for the wind generator.
  #510 (permalink)
Old 04-03-2007
SimonV's Avatar
Back in Oz
SD
I am working on the budget for buying the boat, setting it up and sailing from the US to Australia I will be on the boat most of the time (I hope), my only thought is if there is no wind then I will be on the motor no problem, the wind generator will be on a 10' pole at the stern.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
YACHT BROKER
vB code is On
Wind Orientation Mark Matthews Learning to Sail Articles 0 03-06-2005 08:00 PM
Understanding Apparent Wind Steve Colgate Learning to Sail Articles 0 11-10-2002 08:00 PM
Understanding Apparent Wind Steve Colgate Seamanship Articles 0 11-10-2002 08:00 PM
Understanding Apparent Wind Steve Colgate Racing Articles 0 11-10-2002 08:00 PM
Choosing and Installing Solar Panels Sue & Larry Gear and Maintenance Articles 0 11-06-2000 08:00 PM
Page generated in 1.0666 seconds (75.14% PHP - 24.86% MySQL) with 16 queries
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
