04-06-2007
Cam-
"Brians explanation that the Kuwait performance is based on the clarity of the atmosphere at low angles of the sun "
Clarity of the atmosphere? The standard panel ratings are based on a "perfect" atmospheric clarity. Invoking a better atmosphere is not possible on this planet. "low angles of the sun" ? Again, no. When the sun is at low angles, sunlight has to pass through MORE atmosphere than it does at midday, again, less light falls on the panel than it does under the rating conditions.
So it comes back to a 100-W rated panel producing 100 Watts under optimal conditions. That's 7.24A at 13.8V, the lowest voltage I would call a "charge".
If you could get noon daylight for ten hours, sure, that would produce 72 amp hours of charging power.
Which is forcing me to find out things like "The amount of light received on a sunny day during July and August is about 130 to 160 kilolux". Okay, now we can quantify the amount of light, let's say 150KiloLux (KLux) which means about 150,000 foot-candles of brightness and that morphs into "KiloLux-Hours" when you measure it over time.
So if the noon sun is 150,000 foot-candles in brightness and we can get some similar numbers for other times of the day, we can apply some numbers to this. With extensive searching I came upon "Annual totals were 108, 124 and 122 megalux hours for 1947, 1948 and 1949 respectively with 116 as the mean of the whole series. " referring to Plymouth, England.
So, ignoring global dimming (which has been real) let's say 120 mega-lux-hours in one year, spread on 365 days. That makes a little under 328,800 kilo-lux-hours in any one average day in Plymouth, where the length of the day will vary quite a bit. But--as an average over the year--that's only a bit more than two full "noon hours" of sunlight in a day. Perhaps the total for a summer day is twice as much, i.e. four hours of the noon sunlight rating?
Does any of that sound good enough for some quick late-night back-of-the-envelope sloppy web research? (And I earnestly invite anyone who can, to seek better numbers. Seems like most of the research about sunlight is in scholarly journals that are sold, not simply published on the web.)
