Old 03-09-2007
TXS-ALAMO is on a distinguished road
Question nmea protocalls
What's the difference and advantages between nmea 0183 and 2000? Are all the new electronics compatable with both? If not, is there any advantage in waiting for 2000 or are there adaptors to convert 0183 to 2000? I'm more confused than usual. (which is considerable)
Old 03-09-2007
No, the two standards are not interchangeable. NMEA 0183 is a serial based standard at 4800 baud. NMEA is a much higher speed standard, but I don't recall the exact speed. The wiring is also different. NMEA 2000 uses a special standardized plug, rather than the bare wires you usually find with NMEA 0183 gear.
If you are looking to upgrade, I would go with NMEA 2000 gear, as it has major benefits in terms of simplifying the wiring and data connections on a boat. If you have specific questions, let me know.
ST60 Multi NMEA Interface dave8976 Gear & Maintenance 20 07-23-2010 04:14 PM
windsensor for rotating mast, microPC needed for NMEA correction blubaju Gear & Maintenance 5 02-03-2007 05:56 PM
NMEA stds and Magellan 315 GPS mikehoyt Gear & Maintenance 3 06-05-2002 05:03 AM
The NMEA 0183 Data Sentence Jim Sexton Seamanship Articles 0 10-17-1999 08:00 PM
The NMEA 0183 Data Sentence Jim Sexton Gear and Maintenance Articles 0 10-17-1999 08:00 PM
