coolant loss troubleshooting recommendations? - Page 4 - SailNet Community
post #31 of 39 Old 03-20-2007
resdog's Avatar
If you can't see or smell the coolant and the oil doesn't look like a milkshake, the coolant is either being lost in the heat exchanger or it's being evaporated in a cylinder. Before you get out your wallet, it's time to have a conversation with the people that disturbed your head gasket during the prior service. You can sniff the coolant tank for hydrocarbons when the engine is at operating temps, but you'll need to find someone with a portable gas analyzer to do it.
resdog is offline
post #32 of 39 Old 03-20-2007 Thread Starter
yep i agree. i m guessing its something in the heat exchanger cuz it seems that if it was a cylinder head problem, if you take the radiator cover off it should bubble or gurgle over, and mine doesnt do that...
mrkeith is offline
post #33 of 39 Old 03-20-2007
pigslo's Avatar
One last thought on this in regard to diesels. The compression ratio is so high that any water in the cylinder will blow the head off when it turns to steam upon combustion. That is why the filter separates the water from the fuel.
pigslo is offline
post #34 of 39 Old 03-20-2007 Thread Starter
thats a pleasant thought! well i guess that may mean that it can't be water in the head cuz its hasnt blown off yet?
mrkeith is offline
post #35 of 39 Old 03-21-2007
Larus Marinus
Idiens's Avatar
In the case I have seen, the 4-stroke cylinder on the combustion stroke was blowing gas past the gasket and a water channel. In the process a little water was vapourized and ejected. It only happened at running speed and the exit point was well hidden under the exhaust manifold, so it took an age to detect.
At running speed, the cooling assembly was slightly pressurised and a little above normal boiling point, so taking the radiator cap off was not that advisable. It was a vehicle not a boat engine.
Only speculation: in your case, if the gas is blown by a compression stroke cylinder, past the water channel, into an exhaust stroke cylinder, the water would apparently vanish entirely.
Idiens is offline
post #36 of 39 Old 03-21-2007
resdog's Avatar
Originally Posted by mrkeith
...if it was a cylinder head problem, if you take the radiator cover off it should bubble or gurgle over, and mine doesnt do that...
Not necessarily true.
resdog is offline
post #37 of 39 Old 05-08-2007
Did you ever get this problem resolved? It would be interesting to know what you have found.
DeepFrz is offline
post #38 of 39 Old 05-08-2007 Thread Starter
hi, i 'think' its resolved. i ended up taking off the cylinder heads and having them resurfaced and putting them back together. my guess is that when the boat engine over heated following the 'repair', the heads warped and thats when the leak appeared. anyway, i ve run it for the past 3 weekends and the coolant level is stable so i m hoping that was it! thanks everyone for their thoughts
mrkeith is offline
post #39 of 39 Old 05-08-2007
Either that or you blew the head gasket someplace.
sailingdog is offline
