03-14-2007
Wandering Aimlessly
Yes, you should bevel it for epoxy as well as gelcoat. Ensures a better adhesion. Before putting anything over hardened epoxy, be sure to wipe it off with denatured alcohol.
You could also use Marine-Tex (bondo for boats) instead of epoxy, though I'm not sure if you can gelcoat over that. The advantage is that it is more of a paste, so it won't run or sag from the opening. I've used it on the hull of a previous boat with good results, but not sure what the consensus would be on using it.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love. JCP
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - Website & Blog
