03-18-2007
Many non-skid paints are done by having a "grip" material mixed in or sprinkled on to the wet surface. The ones that use sand tend to be a bit hard on the skin, your clothes and your bare feet. I prefer the ones that use the plastic or rubber granules for the non-skid material. Sanding a non-skid paint to prep it for painting, especially if it has sand as the non-skid additive is going to really suck... the surface will shred the sandpaper almost as fast as the sandpaper will rough/prep the surface.
What you'll probably have to do is strip the old non-skid paint and then start over. Stripping it is probably best done chemically, rather than physically. Scraping sand-laced non-skid paint is generally a bad thing.
