Old 03-18-2007
ibfrisk41
ibfrisk is on a distinguished road
Question Charging motorcycle batteries
My sons Yamaha TT-R125ES has a GT4L-BS 12 volt battery. Can they be recharged using a standard 6/12 volt 10amp battery charger and if so how long should I charge it?
Old 03-18-2007
Is it a wet cell, AGM or Gel battery. If it is a wet cell, then it should be fine with most battery chargers. If it is an AGM or gel, you might need to modify some of the settings for the float charge voltage.
Old 03-18-2007
uspirate's Avatar
Trim for Sail
uspirate has a spectacular aura about uspirate has a spectacular aura about uspirate has a spectacular aura about
I learned the hard way that you have to charge them on the 2 amp setting, the 10 amp setting will cook them dry. i usually charge for 2 hours (start with one hour) just keep an eye on the meter if you have one!
Good luck, BJ
Old 03-18-2007
Is this charger an older ferro-resonant charger or one of the newer intelligent chargers?
Old 03-19-2007
XTR XTR is offline
XTR is on a distinguished road
I charge my bike batteries (HD and Triumph) on a smart charger, it will both float/tend and charge. I've had no problems.
Paralleling Batteries dave.verry Gear & Maintenance 79 11-27-2006 11:19 AM
Charging Batteries Sue & Larry Gear and Maintenance Articles 0 09-25-2002 08:00 PM
