03-18-2007
moderate?
No maintenance other than cleaning with a scotchbrite pad or wire brush (not stainless!) is required. Inspect pin stops for wear and contact factory as needed if wear is severe. Gears are water lubricated so no grease is needed. Don't forget to put a shaft zinc on before you splash!
