03-20-2007
Rather than encasing it in adhesive sealant, I would try using silicone self-fusing tape to seal the leak. Rescue Tape or Rubbaweld are brand names for this tape. It will be easier to clean up.
I also agree you should have a tapered wooden plug, but it should be softwood, like pine, and you need to keep it in a plastic bag, so it stays dry until you need it. That way, when you pound it into the hole, it will absorb water and swell up, essentially holding itself in place...which is why you need to keep it dry.
