Old 03-20-2007
ianhlnd's Avatar
A little less cheek
ianhlnd will become famous soon enough ianhlnd will become famous soon enough
Question Wind generator on a Ketch
I know we've talked about wind generators before, but all applications seemed to be for sloops or cutters. I currently have 4 Kyocera solar panels mounted on swivels on the port and starboard quarters (2 on each side)
Some things you can't do well on a ketch, such as windvane, but does anyone know where a wind generator could be mounted?
I've thought of the mizzen, I already have two radar domes up there, but there is possibly room which would be aft of the swing of the mainsail. Has anyone ever seen such an arrangement, does anyone have a wind generator on a ketch?
Looking for suggestions.
Just checking in.
Where ya'll keep'n the wimmin 'round here?
Old 03-20-2007
Nice Davits Stan...
I think that davits are a possible solution, but it would help if you posted a photo of your boat...
Old 03-20-2007
mike dryver is on a distinguished road
yes you can put a wind genny on your mizzen, but with 2 ray-domes up there already you will quite an amount of weight up there. if your domes are at spreader height you would have to more than likely go higher with the gen. unless your distance forward of mizzen is far enough away from your mainsail and related gear. ie, topping lift etc.
Old 03-20-2007
TrueBlue's Avatar
Seńor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
Stan,
In the future, please try to make your photos larger. They're so tiny they just barely fit on my 50" monitor.
True Blue . . .
sold the Nauticat
Old 03-20-2007
Sorry stan... the second line is to the op... Ian... we have plenty of photos of your boat... But none of the boat in question... LOL...
Old 03-20-2007
Stan-
If you're on a PC...download IrfanView. You can get it here. It has a batch resize function that will make it really simple for you to do that. Any questions, PM me.
EDIT:
Another good program for PC users is Picasa, which you download from here. It is also free.
If you need a program with a bit more capability than either of them... get I-View Multimedia or I-view Multimedia Pro. Read more about them here. Unfortunately, they were recently bought out by Micro$haft...and the product may not remain the stellar product it has been.
Old 03-20-2007
camaraderie's Avatar
moderate?
Ditto Stan...great program and FREE! You can also use it to reduce the colors to 256 which takes file size down and lets you post bigger pictures in the gallery.
Old 03-20-2007
christyleigh's Avatar
christyleigh is on a distinguished road
Another try....
.. Sorry to be hijacking this thread... but us old 'Mainframers' sometimes have trouble with all this PC wizbang stuff... so any way... one of these days I'll mount 2 or 3 panels on the davits, and if I ever add a wind gen I'll attach it to the frame somewhere.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
Old 03-20-2007
aphil138 is on a distinguished road
I have a 42' ketch with a wind generator at the very top of the mizzen and a radar dome about 1/2 way up. I believe I have attached a photo.
Just need to be sure it clears the freshwater stay as it rotates when the wind changes direction. Otherwise it will damage the tips of the blades that will cost you to replace plus shipping plus... the fact that you have get up THERE to fix it.
alan
Old 03-20-2007
TrueBlue's Avatar
Seńor Member
There is another Nauticat 33 ketch on Narragansett Bay, called Penelope, with a rather large wind generator mounted on the mizzen. It too (like mine) has the radar dome positioned on the forward side of the mizzen, so the generator is mounted directly above it.
We've taken moorings nearby each other often in Newport Harbor, but have yet to visit on each other's boats. So, I don't have any technical info or pictures to share. Aside from the cluttered appearance, the arrangement seems to work well.
True Blue . . .
sold the Nauticat
Wind Orientation Mark Matthews Learning to Sail Articles 0 03-06-2005 07:00 PM
Charging with Wind Power Kevin Jeffrey Cruising Articles 0 04-21-2003 08:00 PM
Understanding Apparent Wind Steve Colgate Learning to Sail Articles 0 11-10-2002 07:00 PM
Understanding Apparent Wind Steve Colgate Seamanship Articles 0 11-10-2002 07:00 PM
Understanding Apparent Wind Steve Colgate Racing Articles 0 11-10-2002 07:00 PM
