03-20-2007
Wandering Aimlessly
2 6v in series = 1 12v, then as SD said, you parallel the 3 series wired batteries. Then run your positive lead off the first or last battery and the negative off the opposite of the postive, ie: first battery pos., last battery neg.. Assuming you are using a selector switch, you would run the postive lead to the #2 position stud, and the negative to your common ground. If you have a common postive stud that the both lead is connected to, you can then run a 8ga wire to your panel from the stud, and the negative from the common ground.
If you do have a selector switch, to which your current house bank goes to, then all you should need to do is run the appropriate size cables from the new bank to the switch, just as the current house bank is.
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love. JCP
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - Website & Blog
