03-20-2007
I'd go with Lewmar's winch grease... it's not all that expensive a tube, and a tube goes a long way... and it probably has different anti-corrosion additives for the marine environment.
Grease the bearings, but don't grease the pawls. If you grease the pawls, they'll start to stick and the winch won't work properly. Use a light oil for the pawls.
