03-21-2007
Larus Marinus
OK, I'll nit-pick
Those are the external tank dimensions, the volume is determined by the internal dimensions.
If the tank is made of 2 mm SS, then the theoretical volume drops to around 245 litres, in 8mm plastic it would drop to about 230 litres.
But the dimensions given may not be accurate to 2mm, the tank may bulge, it may not be filled completely, it might not empty completely but I bet 200 litres will go in and get pumped out again.
