Old 03-21-2007
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
Question Going up the mast...
Next week I am going to be headed up the mast primarily to install my new EZ Jax system on the spreaders, mast, and boom. This is my first time, so while I'm up there dangling around heres what I was going to check/inspect. Please advise on anything I may have missed...or should do.
1. Spreaders connection at mast
2. Anything screwed, bolted, etc. into mast for corrosion/tightness
3. The anchor, strobe, & running lights
4. Wind vane
5. VHF Antenna and its wiring
6. Halyards
Thanks
Note: The rig was inspected by the surveyor at purchase but not since (summer of 05) and everything was ship shape.
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 03-21-2007
1970Columbia34's Avatar
1970Columbia34 is on a distinguished road
Send a message via AIM to 1970Columbia34 Send a message via MSN to 1970Columbia34 Send a message via Yahoo to 1970Columbia34
Not on your topic but is there a reason that you picked ez-jacks over the Jiffy Jacks i am trying to pick one of the 2.
Scott
Old 03-21-2007
You should also check the following:
Steaming/foredeck light
Masthead sheaves
Shroud and stay tangs
Old 03-21-2007
T37Chef's Avatar
Saw them at the Annapolis boat show. I choose it primarily because there is no need to retrofit anything. The EZ Jack system retracts when not in use (when raising the main and after it is stored). I have heard several who found that the lazy jack catches the battens, this system eliminates that. I purchased the package that allows you to control it from the cockpit as well.
The price was right too...although someone here said they could rig the same system for $30...? I doubt that? Someone always tells you after you buy something they could do it for less
Thanks agaon Dog...you da man!
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
Old 03-21-2007
Here .. Pull this
Sailormann will become famous soon enough
Just a suggestion...before you haul yourself up in the bos'n chair, if you haven't already done it ... you might want to load the chair up with some weight close to your own and haul her up to make sure that everything is strong enough and properly rigged...
Old 03-21-2007
T37Chef's Avatar
Uh?
WHY?
Great tip...now, if I can only find enough stuff that weighs 200 lbs.
Must exercise more, must exercise more...
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
Old 03-21-2007
LOL... I feel sorry for the poor bastard that has to haul you up the mast... Don't forget to use a second line as a safety line... don't want to see a chef splattered all over the deck in the news...
One thing I've found useful when working in a bosun's chair is a belt to put around the mast, so I don't swing around as much. In the case of a fall, it might help as well... since it would tend to slow you down a bit... especially when it hits the spreaders...
Old 03-22-2007
cpcohen is on a distinguished road
I rigged a retractible set of lazyjacks. Including the line, it was probably about $75 for a 36' boat. Line, s/s rings, s/s u-straps, two cheek blocks, two plastic cleats -- it adds up.
The EZ-Jacks are more elegant, though.
Charles
Old 03-25-2007
Voyager
Columbia9_6 is on a distinguished road
Send a message via Yahoo to Columbia9_6
I weight 190. I went to a rock-climibing store and bought two ascenders. My wife uses a winch as a safety line and I haul myself up with. It works wonderfully.
Old 03-25-2007
jackytdunaway's Avatar
'87 Pearson 27'
jackytdunaway is on a distinguished road
Is it EZ-jacks or EZ-jax. i have been thinking about a sail flaking system and was wondering the pros and cons?
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 11:06 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
