Old 03-21-2007
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
Question Stained gel coat...going nuts here
The boat has staining on the hull gel coat, mostly on the forward port side. Please help, its driving me crazy that I can't get it off!
These are things I have tried with NO success:
3M Super Duty Rubbing Compound
3M Restorer & Wax (Severe)
FSR Gel
EZ On EZ Off Hull Cleaner (West Marine)
Collinites 870 Heavy Duty Wax & Compound
Black Streak Remover
Starbrite Instant Hull Cleaner
SLX
Wet Sanding with 800 grit
The only thing that even came close to removing the stains was "Amazing ROLL-OFF" by Bell Chemical Corp.
HELP...boat has to go in by Friday!!!!!!
PS...Cant afford to have it painted so thats out this year
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 03-21-2007
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
Have you tried Soft Scrub with a scratchy kitchen sponge?
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 03-21-2007
If you were unable to sand it off, then it must be too deep in the gelcoat for any surface treatment to have much effect...
In the past I have partially removed those "yellowish" stains with a cleaning acid available from hardware stores, but it wasn't a long-term fix. (and not a very "green" practice!) We ended up painting.
Old 03-21-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
I have used easy off oven cleaner with 400 grit wet sand paper. Works great on removing paint and I also had luck with some stains.
Old 03-21-2007
camaraderie's Avatar
moderate?
T37.....The Admiral suggests you try:
Mr Clean magic wipes
Clorox Cleanup
Mean Green Cleaner
Oxalic Acid solution
You don't note the cause of the stain...but if it is similar to the famous ICW moustache...the solution is the Oxalic Acid. If just dirty looking and stained...try the others first.
Old 03-21-2007
T37Chef's Avatar
Dont know...
I don't know what the stain is from, but it is not the ICW Mustache (LOL). It's not, but looks like an exhaust stain...it cant be because its primarily on the forward port side near the water line.
Thanks for the suggestions, will try all and post what, if anything suggested worked Keep your fingers crossed.
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
Old 03-22-2007
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
Have had excellent luck with the Soft Scrub and 3M pad as suggested by the Beezer.
Old 03-22-2007
sailortjk1's Avatar
Isn't that way too abrasive?
I would think the 3-m pads would do damage to the Gel.
Old 03-22-2007
rchrdcoe is on a distinguished road
I have used OSPHO in the past with good results. Can be had from a hardware store. I think it is basically Phosphoric acid. Marketed as a rust remover/converter.
Old 03-22-2007
T34C's Avatar
Thanks Courtney.
T34C has a spectacular aura about T34C has a spectacular aura about T34C has a spectacular aura about
Sometimes gelcoat can pick-up tanins that are in the water from a lot of leaves in the fall. (happens alot on inland lakes) It looks like a brownish stain that won't wipe off. Vanish toilet bowl cleaner will usually do the trick.
Maeven
Tartan 34C Yawl #282
Anything-sailing.com
Moderator
gel coat dm567 Gear & Maintenance 15 01-02-2007 11:55 AM
Gel coat questions JoeBailey Boat Review and Purchase Forum 3 09-04-2006 01:20 PM
Gel coat cracks seac Gear & Maintenance 3 12-13-2002 05:46 PM
Gel coat vs epoxy for hull dpoperngr Gear & Maintenance 6 10-28-2002 11:48 PM
gel coat peeler bayme Gear & Maintenance 0 10-08-2002 04:28 PM
