03-23-2007
Best Looking Moderator
Another idea is to stock the crap out of your fridge. Stuffed as much as you can. A filled fridge will reduce the air, reducing the humidity, reducing the condesnsation. It will run more efficiently and will freeze up less. CP is right, if you are low on freon, the lines will freeze. However, it sounds more likely that you are introducing a lot of moisture into the box to me.
Make sense?
Also, I wrote a thread called refrigeration conservation, it is on this board and cruisers forum. Hopefully that will help. If you don't want to go to a lot of trouble on the drain line, just stick a cork in it.
Fair Winds.
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Are you trying to talk your spouse or family into cruising or sailing? Want to know what it is like, every day? Click here and enjoy: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
