03-23-2007
Tubsmacker, if your rigging is "wire over rope" with a rope core, then the rope can absorb water (a bad thing) and oiling the rigging can displace the water (a good thing) and let the rope act to keep an oil film on the wire as well.
Sheep grease, by any other name, is still a water-soluble oil similar to what's in your hair. The big advantage to it is that it is fairly non-staining and biodegradeable.
I've been told to use lanolin in the *fittings* mainly to ensure that water can't get in and then freeze, causing damage. Oiling the rigging itself...I'm not so sure, there's not a lot of lotion between the fibers once they've settled in, is there? What does the manufacturer of your rigging wire recommend?
