03-23-2007
Tenuki-
DSC is much more than just a way to hit a panic button. It can be used in a lot of different ways. For instance, if you have the MMSI of a friend's boat, you can use DSC to send out a request for a radio conversation with them, without using channel 16. You can also transmit your position info to your friend over it, say if you want to raft up for lunch.
