Glue removal question - Page 2 - SailNet Community
post #11 of 12 Old 03-28-2007
Put particle board over it...
Two ideas... one) get some nice wood veneer and finish it off that way... or two) use a laminate veneer, similar to Formica to cover it. It really depends on what kind of boat you're on. If the boat is a newer one, with less wood, and you like the idea of lower maintenance, then the second way is probably better. If you have an older boat with a more traditional interior, then go with the wood veneer.
Either way, you'll get a light, fairly low maintenance, good looking solution.
sailingdog is offline
post #12 of 12 Old 03-28-2007
Or take a decorative painting class, and apply a faux-wood-grain paint finish over whatever is there now?
One heads-up, "Kleen Strip" cover-up stuff is not the same as the "Klean-Strip" solvent spray, confusing the two could either leave you with a puddle of skin around your ankles, or a batch of glue that wasn't coming unstuck.
hellosailor is offline
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
Gorilla Glue on a boat? jr438234606 Gear & Maintenance 14 08-11-2006 08:52 AM
Varnish Removal Question sailortjk1 Gear & Maintenance 4 02-06-2006 03:54 AM
