Raw water pump - Page 3 - SailNet Community
post #21 of 57 Old 03-27-2007
Impellers can get pretty brittle if they're run dry or get too old. Globe makes some that are designed to resist burning out if run dry. Once the impeller gets brittle, the blades break off and get stuck in the cooling system... which is very bad.
sailingdog is offline
post #22 of 57 Old 03-27-2007
Originally Posted by bestfriend
... I had read on another board that it didn't matter which way the impeller was put in because it was rubber and would flip the right way. I find that very hard to believe ..
Actually it's true - the impeller will flip itself around if installed backwards, but I usually try to get it in in the correct orientation "just because"..
When you buy a replacement (which obviously you'll have to do) it should come with a small capsule of silicone lube to put on the impeller to help it seat itself and prevent damage during the initial "dry" run til it primes itself.
Luckily you don't have to find a large number of bits... I'm actually surprised it quit pumping altogether with only one impeller blade missing..... maybe there's more to this yet?
Faster is offline
post #23 of 57 Old 03-27-2007 Thread Starter
Hitchin' a ride
bestfriend's Avatar
What really irks me, besides the extra work, is that I emailed sherwood and asked them if I needed to lube anything before install. They said no.
Oh and I won't be "buying" a replacement. No way. This ones on them.
I think the blade that broke was blocking any flow of water. The pump was probably still running.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
bestfriend is offline
post #24 of 57 Old 03-27-2007
The impeller may have been "prelubed" by Sherwood I suppose, but if it was on the shelf forever the advantage would be lost anyway.
If the blade that broke off is big enough to block flow, then your might get lucky and there won't be a whole lot of other debris to pick out!
Best of luck. (and get 2 impellers.... now!)
Faster is offline
post #25 of 57 Old 03-28-2007
Good luck with the impeller hope it solves everything. No flow seems stange as Faster mentioned. Persistance. Bring some good tunes.
tonic is offline
post #26 of 57 Old 03-28-2007 Thread Starter
Hitchin' a ride
bestfriend's Avatar
I have been in contact with sherwood and they told me to go through the warranty process at the marine store. So, I have to send it back and wait. Meanwhile, I will put the old pump back on. It still works, but the seals are starting to leak. They had suggested that I put it on wrong, but there is no way. It only fits one way. If its installed 180 degrees wrong, the block and throttle assembly is in the way of the hoses. If I switched the hoses, it would be painfully obvious. The discharge hose is only long enough to make it to the closest nipple. But, along with persistence, I will have to have patience and jump through their hoops.
Vaya con Dios
post #27 of 57 Old 03-29-2007
pigslo's Avatar
I put a new impellor in recently and had a hell of a time getting it to prime until I swabed mineral oil on with a q-tip.
pigslo
pigslo is offline
post #28 of 57 Old 03-29-2007
STARBOARD!!
KeelHaulin's Avatar
You are correct; the impeller MUST be in the correct orientation otherwise they will either break or they will remain stuck pointing the wrong direction and wear out quickly. It is possible that the pump you bought was assembled for an engine that rotates in the opposite direction to yours; so the drive shaft for the water pump would be turning the opposite direction. It's important to check your old unit and verify the impeller rotation direction before replacing it with the new unit. Good thing you double checked for water flow before setting out to sail!
KeelHaulin is offline
post #29 of 57 Old 03-29-2007
pigslo's Avatar
It matters not how you compress the vanes, they will right themselves after one rotation.
pigslo
pigslo is offline
post #30 of 57 Old 03-29-2007
pigslo
True... and a GOOD impeller should not break on the first twist, regardless. If it does, then it was dried out and ready to fail anyway.
Lubing with the provided capsule aids this, aids priming and protects the impeller when it runs dry for a few seconds.
Faster is offline
Devising a Better Bilge Pump Don Casey Seamanship Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Gear and Maintenance Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Cruising Articles 0 06-02-2002 08:00 PM
