03-24-2007
Wildcard-
Most of the roller furlers have an aluminum extrusion over the forestay... the luff of the roller furling jib or genoa has a wire that slides into the groove and holds it to the forestay, instead of hanking on.
In general, you can't drop the roller and hank on a sail...it has to be modified to fit the furling groove.
While you don't need a lift to install the top end, to install a roller furling system you have to:
1) disconnect the bottom of the forestay
2) Cut off the swage and then slide the foil sections up the forestay
3) Put on the roller
4) Put on the mechanical terminal fitting — either StaLok, Hi-Mod or Norseman.
5) Re-attach the bottom of the forestay.
If your rigging is more that five years old, most roller furling manufacturers will recommend that you replace the forestay, to install the roller furling unit.
This is a very rough overview of installing a roller furling unit. Details are specific to each brand and model.
