Wood Interior Cabin - Page 2 - SailNet Community
post #11 of 24 Old 04-28-2007
Hitchin' a ride
bestfriend's Avatar
Hey Freesail, Faster and Sabreman, whats the verdict? Curious to know how it turned out.
Best
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
bestfriend is offline
post #12 of 24 Old 04-28-2007 Thread Starter
Freesail99's Avatar
I had posted in another post on How I really messed up. I assumed that my bulkheads were real wood or veneer. Wrong ...... I lightly sanded the surface to touch it up, before I was going to varnish. I removed the wood "finish". It was a laminate.
There are a lot of compound angles and I thought I be buying many, many teak plwood sheets. So I decided to go with "bellawood" pre-finished flooring on the bulkhead walls. What I am using can be found here.
S/V Scheherazade
Freesail99 is offline
post #13 of 24 Old 04-28-2007
Hitchin' a ride
bestfriend's Avatar
Oh, right. Sorry to add salt to the wound.
Vaya con Dios
post #14 of 24 Old 05-22-2007
Sabreman's Avatar
Sorry for replying so late.....I just did a check of old posts.....
The floor came out great. Sanded with 220 grit (changing the paper often), vacuumed up everything, waited an hour to let the dust settle, shut the deck hatches, and tacked the floor in stages as I applied the finish, workingmyself back to the companionway. I'm going to stick with Helmsman's because it's easy to use, readily available, and inexpensive. It's also not a slick as I may have indicated in an earlier post. On my 28, we had curved flooring and we slipped easily. On the 38, everything is flat and I don't notice any slipperiness. We had the boat on a 25 degree heel on Sunday and we walked around with no problems.
I think that regardless of the finish, everything will be slippery if wet (except the nonskid that they use in the Navy - that stuff takes off skin!)
Sabre 38 "Victoria"
Sabreman is offline
post #15 of 24 Old 05-22-2007
Three thumbs up for Ultimate sole.... It goes on easily and dries hard and glossy. Be careful to lay it on wet - a dry brush will leave visible streaks. (Foam brush mandatory - I couldn't find the "expensive" ones they recommend, so used the ordinary ones with success.)
So - I thought, what's wrong with a durable non slippery surface on the salon table? Used US on that too... looks great but it's tough to wipe with a wet cloth - the cloth doesn't want to slide! So I guess the nonskid properties hold true.
Worth the cost, even across the line (ended up close to $100CDN after duties, taxes and shipping!) and it looks like it goes a long way. Used about a 1/3 quart can for two coats on a 35 footer.
Faster is offline
post #16 of 24 Old 05-22-2007
Hitchin' a ride
bestfriend's Avatar
Thanks for the updates guys.
Vaya con Dios
post #17 of 24 Old 11-20-2007
Sorry to revive an older post, but, I will be buying a 4x8 sheet of teak and holly, to put down for the cabin sole this winter. Does it come prefinished, or will I have to use something like, Ultimate sole, or Helmsman.. mentioned above? I want to make sure it looks great, and lasts!!
Northeaster is offline
post #18 of 24 Old 11-20-2007
The plywood you buy for that purpose is unfinished... you will have to apply a finish of your choice or watch it quickly deteriorate. Bummer considering what they charge for those sheets.
As noted above, Ultimate Sole finish seems to be one of the best for high gloss and nonslip properties.
Faster is offline
post #19 of 24 Old 11-20-2007
Aquaholic
AjariBonten's Avatar
And be sure to seal the sides (Endgrain, if it were "real" wood)!! That stuff sucks up moisture like a straw, and will destroy it faster than a run away belt sander!
I got an Old Fat Boat
She's Slow But Handsome
Hard In The Chine, but Soft In The Transom
I Love Her Well, And She Must Love Me
But I think It's Only For My Money
..... Gordon Bok
AjariBonten is offline
post #20 of 24 Old 11-20-2007
Well, considering that you generally have to cut it to size, having it pre-finished would kind of be a pain...since you'd still have to finish the cut edges... by leaving it unfinished, you can at least know that the finish is compatible all around.
sailingdog is offline
rudder, glass or wood? jbarros Gear & Maintenance 8 05-08-2003 09:32 AM
Teak versus Marine Wood RookieHunter Gear & Maintenance 1 11-29-2002 08:30 AM
Soft/Rot Wood on ply in bilge. Rasputin General Discussion (sailing related) 3 06-22-2001 05:01 AM
Soft/Rot Wood on ply in bilge. Rasputin Gear & Maintenance 3 05-11-2001 10:30 PM
