03-27-2007
Blueranger-
One thing you have to check is to make sure that the masthead sheaves are compatible with an all-rope halyard. The sheaves for wire usually have a v-shaped groove, and are considerably smaller than those for rope of the same strength, which have a u-shaped groove. Also, wire halyards can chew up the masthead sheave box exit and may have left burrs that will quickly destroy a rope halyard. It would be wise to check the condition of the masthead sheaves if you're planning on going to an all rope halyard.
The spectra-based lines are very light, and very strong, with very little stretch... about 1-1.5%, which is about the same as wire.
If you race at all, the spectra halyards are definitely worth it, as they allow you better control over your sail shape and are lighter...
Faster-
While the bottom sheave may be okay, the top ones in a wire-to-rope setup are usually setup for wire only, as the rope splice generally doesn't ever reach the exit at the top of the mast.
